Rasterize without resolution loss
Posted: Wed Mar 30, 2022 5:10 pm
by PablerasBCN
When I rasterize I've to eyeball the step so I donĀ“t loss resolution.
When you import back since you've the option to import as point cloud you can then see if you sub or oversampled.
Is there any way to set an step so that 1:1 matches (or very very close) to the source cloud resolution?
Re: Rasterize without resolution loss
Posted: Fri Apr 01, 2022 6:18 am
Do you mean when you try to rasterize a cloud which is already regularly sampled?
Posted: Fri Apr 01, 2022 9:24 pm
by PablerasBCN
No :D, But reading your answer realized if not regularly placed points it may not be possible to 1:1 :D.
But at least could you please add info of the number of points of the current raster instead of displaying in the top, the point number of the original cloud?. or display both info.
Cheers.
Posted: Sat Apr 02, 2022 10:42 am
Do you mean the number of non-empty cells?
Posted: Sat Apr 02, 2022 12:45 pm
Anyway, I added the total number of cells (next to the grid size) and the number of non-empty cells (next to the cloud name and size)
Posted: Mon Apr 04, 2022 7:30 am
by PablerasBCN
Thank you SO MUCH!
