Command Line SF_ARITHMETIC
Posted: Mon Apr 04, 2022 10:23 am
by PablerasBCN
Please add parameter for "Update SF1 directly" so that the operations that support it do not generate new scalar fields, this way we can avoid bloat and unnecesary file size increases. Cheers.
Re: Command Line SF_ARITHMETIC
Posted: Sun Oct 02, 2022 3:39 pm
Not sure if it's still interesting to you, but this is now possible with the -IN_PLACE sub-option.
Posted: Sat Oct 22, 2022 4:40 am
by DaveOZ
Will the command line eventually get the option to apply basic operations to two scalar fields like it's possible in the GUI?
-SF_OP {SF_index1} {operation} {SF_index2}
Posted: Wed Oct 26, 2022 9:22 pm
Do you mean other operations than (+,-,*,/)?
Posted: Sat Oct 29, 2022 8:11 pm
by DaveOZ
Hey Daniel,
no, I’d like to apply these basic operations to two scalar fields using both as operands. So far I only figured out how to use a constant value as the second operand (VALUE in the wiki). But can I use a scalar field index as the value that gets e.g. multiplied with another scalar field index?
I know it works in the GUI but I haven’t achieved that on the command line yet.
Cheers
Posted: Tue Nov 01, 2022 2:53 pm
Ah sorry, I realize the Wiki was not up to date!
There's the -SF_OP_SF command that works the same as the -SF_OP option (but with 2 scalar field indexes). I've updated the wiki, and also the code (so that it can work on meshes just as the -SF_OP option does now) but in the older versions it was already working on clouds at least.
Thanks for the feedback.
Posted: Wed Nov 02, 2022 2:39 am
by DaveOZ
Awesome! Thank you.
