SOR noise filter
J.Sevilla
SOR noise filter
Post by J.Sevilla »
Hi everyone.
I am new to the software. Can someone explain to me what is causing this error:
DoActionSORFilterFAlides to apply the noise to filter ´Scan0´(not enough memory?
The cloud is about 3 billion points.
There is some special configuration to work better
These are the characteristics of the equipment:
OS name Microsoft Windows 10 Pro
Version 10.0.19044 build 19044
Additional OS description Not available
OS Manufacturer Microsoft Corporation
System name HDS-1
System manufacturer System manufacturer
System Model System Product Name
System type x64-based PC
System SKUs
Intel(R) Xeon(R) Processor W-2133 CPU @ 3.60GHz, 3600 Mhz, 6 main processors, 12 logical processors
BIOS version and date American Megatrends Inc. 1001, 04/11/2019
SMBIOS version 3.0
Embedded controller version 255.255
UEFI BIOS mode
Motherboard manufacturer ASUSTeK COMPUTER INC.
WS C422 PRO_SE motherboard product
Motherboard Version Rev 1.xx
Platform role Desktop
Secure Boot State Disabled
Configuration of PCR7 Link not possible
Windows directory C:\WINDOWS
System directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Regional Settings Spain
Hardware Abstraction Layer Version = "10.0.19041.1566"
Username Not available
Time Zone Romance Summer Time
Installed physical memory (RAM) 512 GB
Total physical memory 512 GB
Available physical memory 361 GB
Total virtual memory 554 GB
Available virtual memory 296 GB
Paging file space 42.0 GB
Pagefile C:\pagefile.sys
Kernel DMA Protection Disabled
Virtualization-based security Not enabled
Device Encryption Support Reasons for device self-encryption failure: TPM cannot be used, PCR7 binding not supported, Hardware security test interface failed. The device is not in modern standby mode., A bus or device that supports DMA that is not allowed was detected., TPM cannot be used
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V -Data Execution Protection Yes
Description Drive
Manufacturer (Standard Drives)
Model INTEL SSDPEKNW020T8
Byte/sector 512
Half loaded Yes
Media type Fixed hard drive
Partitions 3
SCSI bus 0
SCSI logical drives 0
SCSI port 1
SCSI Target ID 0
Sectors/track 63
Size 1.86TB (2,048,407,280,640 bytes)
Total number of cylinders 249,038
Total number of sectors 4,000,795,470
Total number of tracks 63,504,690
Tracks/cylinder 255
Partition Disk #0, partition #0
Partition size 499.00 MB (523,239,424 bytes)
Initial partition offset 1,048,576 bytes
Partition Disk #0, partition #1
Partition size 99.00 MB (103,809,024 bytes)
Initial partition offset 524,288,000 bytes
Partition Disk #0, partition #2
Partition size 1.86 TB (2,047,763,021,824 bytes)
Initial partition offset 644,874,240 bytes
Description Drive
Byte/sector 512
Half loaded Yes
Partitions 1
SCSI bus 0
SCSI port 2
SCSI Target ID 0
Sectors/track 63
Tracks/cylinder 255
Partition Disk #1, partition #0
Partition size 1.86 TB (2,048,272,629,760 bytes)
Initial partition offset 135,266,304 bytes
Thank you very much
Re: SOR noise filter
Sadly, due to a technical limitation, CloudCompare can't process clouds bigger than 2 billion points.
PablerasBCN
Post by PablerasBCN »
Considering that limitation, you can super easily chop the input file when opening into CC. When opening the cloud check the "tiling" tab.
