FLS Files processing
Posted: Sun Jun 05, 2022 9:34 am
I'm not sure if there is a quicker way to do this, right now to work on FLS files I have to import one by one, get the normals oriented by the sensor, get the scattering angles and filter the ones closer to 90 degrees. This last part is important, and it is the reason I cannot do it with the command line.
Only after that process I can subsample the scans, because the subsampling will not keep the sensor data.
So 2 questions,
Is there a way to filter by the scattering angles with the command line or some script? or
Is there a way to subsample the scans and keep or copy the sensor data to the subsampled cloud?
So 2 questions,
