Gap filling
Posted: Mon Oct 10, 2022 9:19 am
by T1230321
Hi everyone,
Complete novice here.
I'm wanting to fill some small gaps I have in my scans. Could someone tell me the best way to do this, please?
I have seen other forum posts discussing the topic by using plugins, but I'm not sure how, or where, to get these from.
Any help would be much appreciated.
Some info:
Scanner - FARO X330
Scans processed in Faro Scene and exported as ASCII file
Corresponding xyz file imported into CloudCompare.
Re: Gap filling
Posted: Wed Oct 12, 2022 7:53 pm
I guess the only reliable way to do this is to mesh the cloud (at least locally) with one of the 2 meshing approaches (Delaunay or Poisson - see https://www.cloudcompare.org/doc/wiki/index.php/Methods and https://www.cloudcompare.org/doc/wiki/i ... n_(plugin)) and eventually sample points on the resulting mesh.
But frankly, that looks quite painful ;)
Re: Gap filling
Posted: Thu Oct 13, 2022 12:19 pm
by T1230321
Thanks, Daniel, I will give this a go!
Re: Gap filling
Posted: Thu Oct 13, 2022 8:29 pm
by DA523
- draw plolyline around the hole
- sample polyline into points(1000 points)
- mesh the new points
- sample mesh into points
- merge new points into scan points
- delete extra ployline and mesh etc
Re: Gap filling
Posted: Mon Oct 17, 2022 9:04 am
by T1230321
Hi DA523,
Thanks very much for your reply.
I followed that up until point 5.
How do you go about merging the new points into scan points? The 'merge' option is greyed out for me.
Thanks in advance
Re: Gap filling
Posted: Mon Oct 17, 2022 9:36 pm
by DA523
control+D to select 2 pointsclouds then click merge button
Re: Gap filling
Posted: Thu Oct 20, 2022 12:16 pm
by T1230321
Thanks for your help!
