Can't export .e57 with images
Posted: Fri Mar 17, 2023 7:42 pm
by Cloudcompare_User_6
Hello, I am using the latest version of 2.13 alpha. When I import an .e57 file, I can see the images in the DB tree. However, when if I export to an .e57 and bring it back into CloudCompare, the images are lost and I get a 'failed to load image from blob data' error in the console. I would like to import an .e57 in cloudcompare, make edits, and then export as an .e57 retaining all the images".
Re: Can't export .e57 with images
Posted: Fri Mar 17, 2023 10:07 pm
Ouch! This was a bug. I fixed it. You should download an re-install the latest 2.13.alpha version.
Posted: Wed Mar 22, 2023 6:18 pm
Thanks so much for the quick response!
Posted: Mon Sep 04, 2023 12:55 pm
by Kjaerdk
Hi
I have download the lastest 2.13. Alpha version in hope to export at segmented area off the pontcloud and still keep the images.
Is this not passable ?
I can see the Images of all the setup in the DB tree, But when i am uploading it to Atis-cloud, the Images are not there. What am i doing wrong?
Posted: Sat Sep 16, 2023 10:18 am
I have tested on my side with the latest 2.13.beta version, and it seems to work fine?
Can you retry?
