Page 1 of 2
Clipping with polygon list
Posted: Wed May 17, 2023 7:28 am
by tsch_kl
Hello Daniel,
is it or would it be possible to implement a combination of the two tools?
- 3.png (1.19 MiB) Viewed 7691 times
I want to clip a point cloud based on a given surface (list of coordinates or polygon). If no, do you have an idea, how it could do that manually?
Regards
Thomas
Re: Clipping with polygon list
Posted: Wed May 17, 2023 9:33 pm
You mean you want to clip all the points along one direction that fall within a polygon defined in a plane orthogonal to this direction?
Then your only friend might be the '-CROP2D' command line option (see
https://www.cloudcompare.org/doc/wiki/i ... _line_mode). You'll have first to reorient the cloud so that the polygon can be described only in 2D).
Posted: Tue May 23, 2023 12:02 pm
by tsch_kl
Exactly, I want to cut out all points in a certain polygon considering a normal vector in the orthogonal direction (e.g. 10cm). That is, in a volume of interest = polygon * normal vector.
So yes.
Stupdi question, could not find the answer, but how do I start the command line mode? Unfortunately, I cannot make any entries in the console.
Posted: Tue May 23, 2023 12:03 pm
by tsch_kl
Posted: Tue May 23, 2023 12:16 pm
by tsch_kl
the function -CROP2D {ortho_dim} {n:number of vertices} X1 Y1 X2 Y2 ... Xn Yn is explained as follows:
Crops all loaded clouds inside or outisde a given 2D polyline. Cropping is done in a plane defined by its orthogonal dimension: X, Y or Z (i.e. coordinates along this dimension will be ignored).
Optional settings are:
- OUTSIDE: if defined only the points falling outside the input polyline will be kept (instead of inside by default).
Note:
- result is automatically saved by default (see the AUTO_SAVE command to change this)
each
- cloud will be replaced in memory by its cropped version
Am I able to define the length of the cropped direction? For example 0.1m?
Posted: Tue May 23, 2023 12:27 pm
by tsch_kl
Would it be possible to import a polyline into CloudCompare GUI? Then I also could use the scissors tool. I'd only need to define the orthogonal direction.
Posted: Sat May 27, 2023 9:42 am
So, no, you can't define the depth with CROP2D, it's an 'infinite' crop.
And yes, you can easily import a polyline as .poly file (it's a text file, with the X Y Z coordinates of each vertex per line).
Posted: Fri Jun 02, 2023 8:59 am
by tsch_kl
Is it possible to import the poly file with the GUI?
Posted: Sat Jun 03, 2023 2:07 pm
Yes, .poly files can be imported in the GUI version.
Posted: Thu Aug 10, 2023 6:24 pm
by tsch_kl
Thanks. Did work!
