pan durint segementation
Posted: Mon Nov 13, 2023 2:15 pm
by PablerasBCN
You know that known bug that allows you to pan while doing segmentation with scissors? Please extend it so we can pan.
Why? look, I need to cover the holes left by laser shadows that leave holes here and there. It would be very handy for me to draw the shape of the hole, then pan to nearby facade chunk, clone it so I can fill in the gap. Now I've to eyeball the shape and is a bit of a pain.
Re: pan durint segementation
Posted: Mon Nov 13, 2023 10:28 pm
What bug exactly?
Posted: Tue Nov 14, 2023 11:50 am
by PablerasBCN
some time ago, you said, discussing a similar topic, that it was a known bug that it was left as is, because some people finding it handy, that you can zoom out while segmenting while the selection polyline being active. I'm requesting that it to be expanded so I can pan while segmentation polyline is drawn, so I can cut that exact shape nearby the current hole.
Posted: Tue Nov 14, 2023 12:00 pm
by PablerasBCN
as you said in the ver last pos of this thread, the zooming while segment polyline is a glitch-feature:
https://www.cloudcompare.org/forum/view ... 189#p24189
Posted: Sat Nov 18, 2023 9:40 am
Ah ok. But you wouldn't be able to use the right click as is (it's already used to close the polyline). So we would have to add a shortcut that's not already used: CTRL, SHIFT or ALT + right click).
Posted: Sat Nov 18, 2023 3:40 pm
by jedfrechette
Of all the 3D applications I’ve used the UI I like the best is having a modifier that is held down to activate navigation mode (tumble, pan, dolly, zoom, etc). That frees up all the mouse buttons for usage by tools when the modifier isn’t active.
ALT is a pretty popular choice for the modifier key, but I much prefer SPACE because it is much more comfortable to reach, which is especially important when you’re using it a alot.
Posted: Sat Nov 18, 2023 4:18 pm
by PablerasBCN
daniel wrote: ↑Sat Nov 18, 2023 9:40 am
Understood, since the zoom glitch manifests while Shift + wheel, may be the logical way to do would be Shift+rclick hold for pan.
