The crash occurs in the latest beta 2.13, the currently installed 2.12.4 (flatpak) and the older 2.11 (.deb i think?) which is in the Kubuntu software repo/Discover.
To reproduce, I simply select all scans, click "merge" and when prompted to regen scalar fields I select yes or no (makes no difference) and then the program immediately closes.
Launching CC from the console allows me to capture the below error when it crashes
CloudCompare: /run/build/CloudCompare/libs/qCC_db/src/ccPointCloud.cpp:991: const ccPointCloud& ccPointCloud::append(ccPointCloud*, unsigned int, bool): Assertion `false' failed.
Details of my system:
OS: Kubuntu 23.10 x86_64
Kernel: 6.5.7-060507-generic
Uptime: 27 mins
Packages: 2532 (dpkg), 9 (flatpak), 14 (snap)
Shell: bash 5.2.15
Resolution: 3840x2160
DE: Plasma 5.27.8
WM: KWin
WM Theme: Breeze
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], McMojave-circle-dark [GTK2/3]
Terminal: konsole
Terminal Font: Ubuntu Mono 10
CPU: AMD Ryzen 9 5950X (32) @ 3.400GHz
GPU: NVIDIA GeForce RTX 3060 Ti Lite Hash Rate
Memory: 3980MiB / 31990MiB
