risky behaviour of CLI hwen using -FEATURE
Posted: Thu Dec 14, 2023 3:10 pm
Hello
I've noticed a never before seen behaviour at the time of saving when using CLI. I canĀ“t tell right now if I had never used -feat before, yet I would say I doubt.
The thing is that I was not seeing any file output, and when reading command line I noticed:
[SAVING]
[LAS] scalar field Eigenentropy (0.132) will be saved automatically in the extra fields of the output file
[I/O] File 'E:**************/08OE2704_temp.las' saved successfully
Processed finished in 305.32 s.
So I opened and I confirmed it was overwriting files.
THANKFULLY.
theese files had already the SF removed because are the output files of a .bin, but could have been cathastrophic.
I've been few months without using CLI, but I would say, that even without timestamp, which I allways remove, there was extra info added to the name, like the commands used and may be values, but not this time.
The very least would be at the launch of the bat to be warned that files will be overwritten.
my .bat file looks like:
for %%f in (E:\************\02_VegetationOnly_ColorFixed\*.las) DO "C:\Program Files\CloudCompare\cloudcompare.exe" -SILENT -O -GLOBAL_SHIFT AUTO %%f -AUTO_SAVE OFF -C_EXPORT_FMT LAS -NO_TIMESTAMP -REMOVE_ALL_SFS -FEATURE EIGENTROPY 0.132 -SAVE_CLOUDS
[SAVING]
THANKFULLY.
