CC slows down quickly after several times segmenting
candrastefan
Post by candrastefan »
Hello. I've been using CloudCompare to segment 3D point clouds and it's been working well. However, after several times segmenting (which also involves zooming in/out and rotating the point cloud), the program slows down tremendously. I suspect there is a memory leak somewhere. I have tried both Linux and Windows version and they both have the same problem of slowing down. Does anybody have the same problem? How do I solve this? Thanks.
Re: CC slows down quickly after several times segmenting
This one is a little bit weird. I'll try to reproduce it on my side (maybe a vbo issue once again though).
candrastefan
I unticked "Try to load points on GPU.." option in Display settings and it helped alleviate the lagging problem, but didn't solve it. CC becomes progressively slower, but at a reduced rate. I am using the Linux version, if that helps.
Aarie
Post by Aarie »
I can confirm this issue on Win 7 (CC v.2.6.1.beta).
