Transformation Error when Exporting from BIN File
Posted: Sat Apr 18, 2015 4:01 pm
I used the "Align (Point Pairs Picking)" tool to align two lidar scans of a forest and am having trouble saving the aligned point clouds.
The tool worked very well and I have the two point clouds properly aligned in a BIN file, but whenever I attempt to merge or save the files, the point cloud that was translated loses its transformation and is saved in its original (incorrect) position.
I am using CC 2.6.1 64 bit on Windows and have tried to save the translated file in every export format possible, but have still had the same problem. I also tried writing the coordinates to a scalar field, but that did not seem to work either. These point clouds were time consuming to align, so I hope we can figure out a solution!
Thanks for all your hard work on CC, I'm a new user, but I really like the program so far.
