Point Cloud color
Posted: Sun Oct 25, 2015 1:37 pm
I have some scans from a Faro Focus3D where the color is captured in a panoramic image. When I open these scans in Cloud Compare, I have a choice of using the RGB or reflectance values. However, choosing RGB however does not import any color.
When I open the the same scans in ReCap, the color is imported, which is apparently projected onto the points from the image. However, exporting an E57 file from ReCap, has no color.
Is it true that color that is not directly sampled at the point when its captured (as in the case of the projected image) has limited support?
