HELP (radius and Cms)
Posted: Fri Jun 02, 2017 7:31 pm
Hi Daniel, I need your help!!
You said here http://www.danielgm.net/cc/forum/viewtopic.php?t=1032
"Well if you can measure the actual "distance" (unitless) between two points (with the Point Picking Tool for instance), you should then be able to find the right scale factor to convert your cloud in cms (simply use the 'Edit > Scale' tool to do that). Once that's done, all your measures will be in cms."
And I have two questions:
1) In CloudCompare, In "Edit" I don´t find "Scale". Can you explain this? I know the distance between two points (0.005 ( unknow units)), and I have to change the scale for Cms but I don´t find where picking.
2) How can I know the radius of the points in CloudCompare? I pick some points and i don´t have this information.
Thank you so much.
Thank you so much.
